Can not add a tracking entry on a port on which TCP tracking is already enabled. API call to Nettools to add a tracking entry has failed.
Check TCP tracking state on port. If tracking state is already enabled, do not attempt to re-enable it.
Error
Adding TCP tracking functionality for port %port% failed because the tracking state is already enabled.
| Name | Type |
| port | SlotPort |
